LoginCode Method
The LoginCode method logs in using a code.
    SiteKiosk.Plugins("SiteCash").Devices("SiteCafeClient").
    LoginCode(code)
    code String that specifies the code.
    The following example logs in using a code.
    SiteCafe.LoginCode("your_code");
